show ssh2 private-key
Description
Displays the ssh2 server‘s private key.
Syntax Description
Default
N/A.
Usage Guidelines
This command displays the ssh server‘s private key which can be used to configure the key later or on another switch by using the configure ssh2 key {pregenerated} command. The key is saved in the switch‘s EEPROM.
To erase the key from the EEPROM, use the unconfigure switch command.
This command was added to ExtremeXOS 11.6 SR, and ExtremeXOS 12.0 SR.
Platform Availability
